How to specify the location of MrMC data
Revision as of 04:58, 12 October 2018 by Koying (talk | contribs)
MrMC supports a backdoor to specify the location of your MrMC data.
To do so, create a file name mrmc_env.properties in the root of your external storage (normally, "/sdcard"). Its content is simply:
xbmc.data=<path to the xbmc data root>
e.g. xbmc.data=/storage/sdcard0/external_sdcard/xbmc_data
Inside this, a directory ".mrmc" will be created which contain the user folder structure ("addons", "userdata", ...). Currently, the specified path must be an android one, i.e. no "smb://" or "nfs://", but you can specify any directory mounted on the android FS, including samba or NFS ones.
Note that the standard Kodi xbmc_env.properties is also supported. If mrmc_env.properties is not found, MrMC will look for xbmc_env.properties as a fallback.
Keypair list
Key Value
xbmc.data Specify an alternate path for MrMC data (eg "/storage/sdcard0/external_sdcard/xbmc_data"). Path must exist.
mrmc.obb Alternate location for MrMC OBB (Development)
mrmc.autostart Autostart MrMC after boot (yes/no)
xbmc.jsonPort Alternate JSON-RPC port
xbmc.jsonUser JSON-RPC user, if applicable
xbmc.jsonPwd JSON-RPC password, if applicable
