How to specify the location of MrMC data
Revision as of 13:07, 1 July 2018 by Amet (talk | contribs)
MrMC supports a backdoor to specify the location of your MrMC data.
To do so, create a file name mrmc_env.properties in the root of your external storage (normally, "/sdcard"). Its content is simply:
xbmc.data=<path to the xbmc data root>
e.g. xbmc.data=/storage/sdcard0/external_sdcard/xbmc_data
Inside this, a directory ".mrmc" will be created which contain the user folder structure ("addons", "userdata", ...). Currently, the specified path must be an android one, i.e. no "smb://" or "nfs://", but you can specify any directory mounted on the android FS, including samba or NFS ones.
Note that the standard Kodi xbmc_env.properties is also supported. If mrmc_env.properties is not found, MrMC will look for xbmc_env.properties as a fallback.
