Siri remote
Revision as of 14:12, 13 February 2018 by Amet (talk | contribs)
Siri Mode
In version 3.5.0 we have introduced new Siri remote handling, more tvOS like.
Select Siri mode in Settings -> System -> Input Devices -> Enable Siri expert mode (disabled by default) if you would like to go back to how things were before 3.5.0 release
tvOS Native Mode:
Basic Controls
1 - Touch pad, swipe and tap for directional navigation, Click for select or entering the menu item.Click and Hold brings out context menu
2 - Menu, will exit playing file or go back in menu hierarchy
3 - Back to Apple TV home screen
6 - Play/Pause
Pan Controls
  • Pan is a slow finger movement over the Siri Remote pad, focus will track movement in any direction, Up/Down/Left/Right.
Swipe Controls
  • Swiping in any direction, faster the swipe more places it moves.
Tap Controls
Select Controls
  • Select is a button press of the Siri Pad and can be done over the entire pad area..
During video playback
  • Left click: seek backward 10 seconds (default settings)
  • Left click hold down: change to 4x rewind, resume 1X play on release
  • Right click: seek forward 30 seconds (default settings)
  • Right click hold down: change to 4x fastforward, resume 1X play on release
  • Up click: next chapter or up channel (pvr)
  • Down click: previous chapter or down channel (pvr)
  • Single Tap: show progress bar
  • Double Tap: ignored
  • Triple Tap: toggle subtitles
  • Center Click -> pause playback -> bring up progress bar (with scrubber if possible)
    • Siri Remote, swipe left/right: Moves progress bar backward/forwards
      • Select click to jump and resume 1X play.
    • Siri Remote, swipe down: Brings up OSD Settings for substitles/audio/video.
      • Menu to back out.
    • IR Remote, click left/right: Moves progress bar 10 seconds backward/forwards.
    • IR Remote, click hold left/right: Moves progress bar 10 (30 after 1.5 seconds) backward/forwards.
      • After release, Select click to jump to that position.
    • IR Remote, Down click: Brings up OSD Settings for substitles/audio/video.
      • Menu or Swipe Up to back out.
    • Menu: resumes 1X playback
Expert Mode:
Basic Controls
6 - Play/Pause
Pan Controls
Note: Pan and hold will trigger auto repeat, fast scrolling action.
Swipe Controls
  • Swiping in any direction will move by maximum 5 places, faster the swipe more places it moves.
Settings
  • Force Siri swipe to move only one place is enabled by default, disabling it will allow fast swipe to move up to 5 places.
  • Swipe action and zoom/slide effects can be disabled in Input settings.
Note: Swipe and hold will trigger auto repeat, fast scrolling action.
Edge Swipe Controls
  • Edge swipe is useful in long lists, it sends PageUp/PageDown command that will scroll the entire page.
Tap Controls
Note: Tap and hold will trigger auto repeat, fast scrolling action.
Select Controls
