Siri Mode
In version 3.5.0 we have introduced new Siri remote handling, more tvOS like.
Select Siri mode in Settings -> System -> Input Devices -> Enable Siri expert mode (disabled by default) if you would like to go back to how things were before 3.5.0 release
tvOS Native Mode:
Basic Controls
- 1 - Touch pad, swipe and tap for directional navigation, Click for select or entering the menu item.Click and Hold brings out context menu
- 2 - Menu, will exit playing file or go back in menu hierarchy
- 3 - Back to Apple TV home screen
- 4 - Volume control (No function in MrMC)
- 5 - Siri (No function in MrMC)
- 6 - Play/Pause
Pan Controls
- Pan is a slow finger movement over the Siri Remote pad, focus will track movement in any direction, Up/Down/Left/Right.
Swipe Controls
- Swiping in any direction, faster the swipe more places it moves.
Tap Controls
- Tapping the edges of the pad will move by one position on the screen
Select Controls
- Select is a button press of the Siri Pad and can be done over the entire pad area..
During video playback
- Left click: seek backward 10 seconds (default settings)
- Left click hold down: change to 4x rewind, resume 1X play on release
- Right click: seek forward 30 seconds (default settings)
- Right click hold down: change to 4x fastforward, resume 1X play on release
- Up click: next chapter or up channel (pvr)
- Down click: previous chapter or down channel (pvr)
- Single Tap: show progress bar
- Triple Tap: toggle subtitles
- Center Click -> pause playback -> bring up progress bar (with scrubber if possible)
- Siri Remote, swipe left/right: Moves progress bar backward/forwards
- Select click to jump and resume 1X play.
- Siri Remote, swipe down: Brings up OSD Settings for substitles/audio/video.
- IR Remote, click left/right: Moves progress bar 10 seconds backward/forwards.
- IR Remote, click hold left/right: Moves progress bar 10 (30 after 1.5 seconds) backward/forwards.
- After release, Select click to jump to that position.
- IR Remote, Down click: Brings up OSD Settings for substitles/audio/video.
- Menu or Click Up to back out.
- Menu: resumes 1X playback
Expert Mode:
Basic Controls
- 6 - Play/Pause
Pan Controls
Note: Pan and hold will trigger auto repeat, fast scrolling action.
Swipe Controls
- Swiping in any direction will move by maximum 5 places, faster the swipe more places it moves.
Settings
- Force Siri swipe to move only one place is enabled by default, disabling it will allow fast swipe to move up to 5 places.
- Swipe action and zoom/slide effects can be disabled in Input settings.
Note: Swipe and hold will trigger auto repeat, fast scrolling action.
Edge Swipe Controls
- Edge swipe is useful in long lists, it sends PageUp/PageDown command that will scroll the entire page.
Tap Controls
Note: Tap and hold will trigger auto repeat, fast scrolling action.
Select Controls
