Siri remote
Revision as of 09:40, 3 July 2017 by Amet (talk | contribs)
Basic Controls
1 - Touch pad, swipe and tap for directional navigation, Click for select or entering the menu item.Click and Hold brings out context menu
2 - Menu, will exit playing file or go back in menu hierarchy
3 - Back to Apple TV home screen
6 - Play/Pause
Pan Controls
  • Pan is a slow finger movement over the Siri Remote pad, focus will track movement in any direction, Up/Down/Left/Right.
Note: Pan and hold will trigger auto repeat, fast scrolling action.
Swipe Controls
  • Swiping in any direction will move by maximum 5 places, faster the swipe more places it moves.
Settings
  • Force Siri swipe to move only one place is enabled by default, disabling it will allow fast swipe to move up to 5 places.
  • Swipe action and zoom/slide effects can be disabled in Input settings.
Note: Swipe and hold will trigger auto repeat, fast scrolling action.
Edge Swipe Controls
  • Edge swipe is useful in long lists, it sends PageUp/PageDown command that will scroll the entire page.
Tap Controls
Note: Tap and hold will trigger auto repeat, fast scrolling action.
Select Controls
  • Select is a button press of the Siri Pad and can be done over the entire pad area..
