Codec Info
Parent topic: Reporting bugs
| 1 | Enable the web server To make it easy to access MrMC from another computer on the same network, enable the built-in web server:
| 2 | Find your IP address
From MrMC's home screen, tap the system settings "gear" icon. Then tap the "i" icon. Note the IP address listed under "General". |
| 6 | Using the IP address you got from Step 3, go to another computer on the same local network and type in
Where Click "Codec" button on virtual remote, NOTE: MrMC will only show Codec Information if video is playing |
