Codec Info
Parent topic: Reporting bugs
1 Enable the web server
To make it easy to access MrMC from another computer on the same network, enable the built-in web server:
In MrMC home screen -> Settings (the "gear" icon on touch devices) -> System -> Services and turn on Allow Remote control via HTTP
2 Find your IP address
From MrMC's home screen, move over to the "System" tab and then select the lower-menu item called "System information". Note the IP address listed under "Summary".
3 Remote Control
http://IPADDRESS:8080
Where IPADDRESS is the number you got before. For example, if your IP address was 10.0.0.5 you would to go http://10.0.0.5:8080
Click "Codec" button on virtual remote, NOTE: MrMC will only show Codec Information if video is playing
3 Remote Control
