Siri remote
Basic Controls
1 - Touch pad, swipe and tap for directional navigation, Click for select or entering the menu item.Click and Hold brings out context menu
2 - Menu, will exit playing file or go back in menu hierarchy
3 - Back to Apple TV home screen
6 - Play/Pause
Swipe Controls
  • Swiping in any direction will move by one position on the screen.
Settings
  • If above setting is enabled, number of moves will depend on the swipe speed (max 5).
Note: Swipe can be disabled in OSD, which prevents accidental ff/rw when picking up the remote.
Tap Controls
