Siri remote
Revision as of 05:52, 2 November 2016 by NedScott (talk | contribs)
Basic Controls
  1. - Touch pad, swipe and tap for directional navigation, Click for select or entering the menu item.Click and Hold brings out context menu
  2. - Menu, will exit playing file or go back in menu hierarchy
  • - Back to Apple TV home screen
6 - Play/Pause
Swipe Controls
• Swiping in any direction will move by one position on the screen
• If above setting is enabled, number of moves will depend on the swipe speed(max 5)
Swipe can be disabled in OSD, this prevents accidental ff/rew when picking up the remote
Tap Controls
