Siri remote
Basic Controls
- - Touch pad, swipe and tap for directional navigation, Click for select or entering the menu item.Click and Hold brings out context menu
- - Menu, will exit playing file or go back in menu hierarchy
- 3 - Back to Apple TV home screen
- 4 - Volume control (No function in MrMC)
- 5 - Siri (No function in MrMC)
- 6 - Play/Pause
Swipe Controls
- • Swiping in any direction will move by one position on the screen
- • If above setting is enabled, number of moves will depend on the swipe speed(max 5)
- Swipe can be disabled in OSD, this prevents accidental ff/rew when picking up the remote
Tap Controls
