Template:Image frame
Revision as of 23:32, 28 June 2016 by NedScott (talk | contribs) (36 revisions imported: formatting templates from kodi wiki)
[edit] Template documentation
This template creates a frame like those surrounding images. This template can be used to put two or more images into a frame together, or as a wrapper for more complicated templates like {{superimpose}}.
Usage
{{Imageframe|width=|content=|caption=|link=|align=|pos=}}
Parameters
Required
  • width: the width of the image within the frame, in pixels (though do not add "px" to the width: ie, use width=175 and not width=175px)
  • content: content of the main section (generally images)
Optional
  • caption: content of the caption section
  • link: link for the "Enlarge" link in the caption (in the future, may also be used as the link for the image field inside the frame, though it would probably require an additional height parameter)
  • linkoverride: allows anything to be used instead of the 'info' link
  • align: Valid values: right (default), left, center.
  • pos: Where to put the caption. Valid values: top, bottom (default)
Examples
By filling out the parameters as follows, the result will be as shown below the code.
{{Imageframe|width=200|content=[[Image:Example.png|100px]][[Image:Example.png|100px]]|caption=Example usage|link=Hello world|align=center}}
Example usage
{{Imageframe|width=200|content=[[Image:Example.png|100px]][[Image:Example.png|100px]]|caption=Example usage|link=Hello world|align=center|pos=top}}
Example usage
