Template:Key press/doc
< Template:Key press
Revision as of 23:30, 19 February 2012 by 50.132.80.72 (talk) (→‎Keystroke combinations)
Example:
{{key press|A}} produces A
This template currently handles up to 5 key name parameters; more than enough to accomodate for any possible combined key stroke. If it gets too many key name parameters it reports the page into Category:Wikipedia keypress template parameter needs fixing. This means we can easily find those pages and fix them, or we can discover if we need to make this template take more parameters.
Wikilinks
{{key press|[[Alt key|Alt]]}} produces Alt
Wiki characters
However, if the characters are marked as wikilinks, they can be entered as such:
{{key press|[[|]]}} produces |
{{key press|[[;]]}} produces ;
{{key press|[[=]]}} produces =
If you don't want to mark the characters as links, {{key press|<nowiki>|</nowiki>}} is also an option.
Key symbols
{{key press|Up}} produces
{{key press|Down}} produces
{{key press|Left}} produces
{{key press|Right}} produces
Windows key and Menu key
Old-style Windows key
Video games
Directional input
PlayStation
{{key press|ex}} produces ×
{{key press|circle}} produces
{{key press|triangle}} produces
{{key press|square}} produces
Technical details
See also
Template:Var/seealso
Not to be confused with
  • {{Button}} – produces a similar visual effect, but without the semantic markup, e.g. sample text
