Template:Key press/doc
< Template:Key press
Revision as of 21:28, 30 September 2011 by 72.211.252.69 (talk)
Example:
{{key press|A}} produces A
Keystroke combinations
This template currently handles up to 10 key name parameters. If it gets too many key name parameters it reports the page into Category:Wikipedia keypress template parameter needs fixing. This means we can easily find those pages and fix them, or we can discover if we need to make this template take more parameters.
Wikilinks
{{key press|[[Alt key|Alt]]}} produces Alt
Wiki characters
However, if the characters are marked as wikilinks, they can be entered as such:
{{key press|[[|]]}} produces |
{{key press|[[;]]}} produces ;
{{key press|[[=]]}} produces =
If you don't want to mark the characters as links, {{key press|<nowiki>|</nowiki>}} is also an option.
Key symbols
{{key press|Up}} produces
{{key press|Down}} produces
{{key press|Left}} produces
{{key press|Right}} produces
Windows key and Menu key
Old-style Windows key
Technical details
See also
  • {{PlayStation key press}} - for indicating PS-style gamepad key presses, e.g. Template:Pskeypress
  • {{kbd}} - for indicating longer input strings like usernames (doesn't simulate the appearance of keys)
  • {{samp}} - for example output
  • {{code}} - for computer source code generally
  • {{var}} - for computer and mathematics variables
  • {{varserif}} - same as {{var}} but differentiates better between "I" (upper-case "i") and "l" (lower-case "L")
