Template:Key press/doc
Example:
{{key press|A}} produces A
Keystroke combinations
This template currently handles up to 10 key name parameters. If it gets too many key name parameters it reports the page into Category:Wikipedia keypress template parameter needs fixing. This means we can easily find those pages and fix them, or we can discover if we need to make this template take more parameters.
Wikilinks
{{key press|[[Alt key|Alt]]}} produces Alt
Wiki characters
Some wiki markup character, like the Pipe symbol, the Semicolon and the Equals sign, need to be entered using the {{!}}, {{;}} and {{=}} templates:
However, if the characters are marked as wikilinks, they can be entered as such:
{{key press|[[|]]}} produces |
{{key press|[[;]]}} produces ;
{{key press|[[=]]}} produces =
If you don't want to mark the characters as links, {{key press|<nowiki>|</nowiki>}} is also an option.
Key symbols
{{key press|Up}} produces
{{key press|Down}} produces
{{key press|Left}} produces
{{key press|Right}} produces
Windows key and Menu key
Old-style Windows key
Technical details
See also
  • {{pskeypress}} – For PlayStation-style controllers.
