Template:Key press/doc
< Template:Key press
Revision as of 10:38, 6 June 2010 by 78.60.86.110 (talk)
This is the {{key press}} template.
It can be used to illustrate keystrokes.
Example:
{{key press|A}} produces A
{{key press|[[Alt key|Alt]]}} produces Alt
{{key press|[[Alt key|Alt]]|P}} produces Alt+P
{{key press|[[Ctrl]]|Alt|Del}} produces Ctrl+Alt+Del
Key symbols
{{key press|Eject}} produces Eject
{{key press|Page Up}} produces Page Up
{{key press|Page Down}} produces Page Down
{{key press|Up}} produces
{{key press|Down}} produces
{{key press|Left}} produces
{{key press|Right}} produces
Windows key
Menu key
We have no characters for the Windows key and menu key. And we perhaps can't add the "real" icons for them for copyright reasons. So we usually show them the following way:
{{key press|Win}} or {{key press|Win key}} produces  Win or Win key
Technical details
This template currently handles up to 5 key name parameters. If it gets too many key name parameters it reports the page into Category:Wikipedia key press template parameter needs fixing. This means we can easily find those pages and fix them, or we can discover if we need to make this template take more parameters.
See also
  • {{pskeypress}} – For PlayStation-style controllers.
