Template:Key press/doc
< Template:Key press
Revision as of 06:43, 3 April 2010 by 189.146.185.85 (talk) (changed to reflect the added ⊞ "windows" key (please cleanup style if you find it far from perfect))
This is the {{keypress}} template.
It can be used to illustrate keystrokes.
Example:
{{keypress|A}} produces A
{{keypress|[[Alt key|Alt]]}} produces Alt
{{keypress|[[Alt key|Alt]]|P}} produces Alt+P
{{keypress|[[Ctrl]]|Alt|Del}} produces Ctrl+Alt+Del
Key symbols
{{keypress|Shift}} produces  Shift
{{keypress|Enter}} produces  Enter
{{keypress|Cmd}} produces  Cmd
{{keypress|Opt}} produces  Opt
{{keypress|Tab}} produces Tab
{{keypress|Backspace}} produces ← Backspace
{{keypress|Up}} produces
{{keypress|Down}} produces
{{keypress|Left}} produces
{{keypress|Right}} produces
Windows key
Menu key
We have no characters for the Windows key and menu key. And we perhaps can't add the "real" icons for them for copyright reasons. So we usually show them the following way:
{{keypress|Win}} or {{keypress|Win key}} produces  Win or Win key
{{keypress|Menu}} produces  Menu
Technical details
{{keypress|Ctrl}} + {{keypress|Alt}} + {{keypress|Del}} produces Ctrl + Alt + Del
This template currently handles up to 5 key name parameters. If it gets too many key name parameters it reports the page into Category:Wikipedia keypress template parameter needs fixing. This means we can easily find those pages and fix them, or we can discover if we need to make this template take more parameters.
This template calls {{keypress/core}}, which holds the code that otherwise would be repeated several times in {{keypress}}, thus simplifying the code.
See also
  • {{pskeypress}} – For PlayStation-style controllers.
