Settings
Revision as of 08:27, 25 December 2016 by Amet (talk | contribs)
This section covers MrMC's various settings and where to find them.
System settings
Most of MrMC's global settings can be configured via the GUI (Graphical User Interface) under Settings (labeled "System" under the default skin).
Note:
There are tiered settings levels. Each mode unlocks more settings, and is available by selecting the "Settings level" button, which will also display the currently used level.
Subtitle Settings
1
From MrMC's home screen, go to Settings -> Video -> Subtitles.
2
Select the languages you want to get when searching for subtitles.
3
Select default Service for TV Shows and Movies.
4
Here you can select default one to use.
