Debug log
Revision as of 21:36, 16 September 2016 by NedScott (talk | contribs)
1 Enable debug logging
The normal log file doesn't contain debugging information by default. To capture this information to the log you must first enable debug logging:
In MrMC home screen -> Settings -> System -> Logging and turn on Enable debug logging
2 Enable the web server
To make it easy to access the log file from another computer on the same network, enable the built-in web server:
In MrMC home screen -> Settings -> System -> Services and turn on Allow Remote control via HTTP
3 Find your IP address
TV users
Touch screen users
From MrMC's home screen, tap the system settings "gear" icon. Then tap the "i" icon. Note the IP address listed under "General".
4 Restart MrMC
In order to record valuable startup information in the log, please quit MrMC completely and then re-open the program. The easiest method would be to simply restart your device, but for specific details see here.
5 Capture the problem
Once MrMC has started back up, give it a minute to "settle down", as various processes occur on a fresh startup. Then proceed to do whatever it is that triggers the bug or issue you are reporting. For example, if playing back a video causes an issue, play back that video.
6 Download the log
http://IPADDRESS:8080
Where IPADDRESS is the number you got before. For example, if your IP address was 10.0.0.5 you would to go http://10.0.0.5:8080
Here you can access your current log file.
Old log
If you are asked for the "old log", which is a log from the last time MrMC was running, you can use this address format to access it: http://IPADDRESS:8080/vfs%2Fspecial%3A%2F%2Flogs%2Fmrmc.old.log
7 Posting your log file online
Select and copy the whole log from your web browser. Then go to a paste website such as http://pastebin.com and make a new "paste" by pasting the log and submitting. Note the URL of your new log paste and give that link to whoever asked for your log.
8 Turn off debug logging
In MrMC home screen -> Settings -> System -> Logging and turn off Enable debug logging
Optionally, you can also turn off the web server if you do not use it for other features:
In MrMC home screen -> Settings -> System -> Services and turn off Allow Remote control via HTTP
Notes
