MySQL
Revision as of 13:32, 29 August 2016 by NedScott (talk | contribs) (prepping for Tabber)
Compatibility
Please Note: Don't create the MySQL databases on your server. Simply set up the MySQL server itself, as mrmc will create the specific databases by itself.
<tabber> tab1 = Ubuntu Linux Ubuntu Linux:
  1. $sudo apt-get install mysql-server (see also: https://help.ubuntu.com/10.04/serverguide/C/mysql.html )
  2. Create a password when asked
  3. To configure MySQL to listen for connections from network hosts, edit /etc/mysql/my.cnf and change the bind-address directive to the server's IP address:
    1. from: bind-address = 127.0.0.1
    2. to: bind-address = 192.168.0.5
    • Note: Replace 192.168.0.5 with the appropriate address.
    • Note: To allow both local and remote access (i.e. from both the MySQL host to itself and also from other clients), either comment out the bind-address using a hash (#) to disable it, or use bind-address = 0.0.0.0 to open it completely.
  4. Restart your MySQL server. $sudo restart mysql
  5. Get into the MySQL command line utility: $mysql -u root -p
  6. Enter the following commands:
    1. Type in: CREATE USER 'mrmc' IDENTIFIED BY 'mrmc'; and press return
    2. Type in: GRANT ALL ON *.* TO 'mrmc'; and press return
    3. Type in: flush privileges; and press return
  7. Close out the command line tool with \q
tab2 = Arch Linux Arch Linux:
  • Please note: Arch, along with many other distributions, has migrated to the faster and more open MariaDB. It is a drop in replacement to MySQL and, thus, mrmc will require no modifications to work with it.
  1. Install MariaDB: $ sudo pacman -S mariadb
  2. Start the service: $ sudo systemctl start mysqld
  3. To have it automatically launch at startup: $ sudo systemctl enable mysqld
  4. Create a password: $ /usr/bin/mysql_secure_installation This will also clean up the demo database.
  5. Get into the MariaDB command line utility: $ mysql -u root -p
tab3 = RedHat based Linux RedHat based Linux (RHEL, CentOS, Fedora):
  1. $sudo yum install mysql-server
  3. To configure MySQL to listen for connections only from network hosts, edit /etc/mysql/my.cnf and add the bind-address directive to the server's IP address:
    • Note: Alternatively you can leave this file as is to allow local and remote access.
  4. Restart your MySQL server. $sudo /sbin/service mysqld restart
    • Recommended - Set your MySQL root password with /usr/bin/mysqladmin -u root password 'new-password'
    • Enter your MySQL root password as set above, or just press enter if you didn't set one to log in with a blank password
Tab4 = Mac OS X Mac OS X:
  1. Download a copy of MySQL server from http://dev.mysql.com/downloads/mysql/
  2. In Mac OS X, go to System Preferences -> MySQL, and click on “Start MySQL Server”. You’ll also want to tick to enable the “Automatically … on Startup” option.
  3. Now to set up the "mrmc" user in MySQL and give it access. Launch Terminal.app on your Mac and issue the following commands, one line at a time:
    1. sudo /usr/local/mysql/bin/mysql
    2. CREATE USER 'mrmc' IDENTIFIED BY 'mrmc';
    3. GRANT ALL ON *.* TO 'mrmc';
    4. exit
  4. Remain in Terminal.app. Now you'll be giving other computers on your network access to MySQL. Enter the next set of commands, one line at a time:
    1. cd /usr/local/mysql/support-files/
    2. sudo cp my-huge.cnf /etc/my.cnf
      The command line will ask for your Mac OS X user password. Enter it and press return. No text will show when you type your password in, this is normal.
    3. cd /etc
    4. sudo nano my.cnf
      This opens a file in a command line text editor
    5. Scroll down to the [mysqld] section and add or edit the following line so that it appears as:
    6. Save and exit from the command line text editor
  5. Reboot the Mac, or restart the MySQL service from the System Preferences pane you installed earlier
tab5 = Windows
Installing MySQL on Windows
or
  1. Download a copy of MySQL server from http://dev.mysql.com/downloads/mysql/ (Grab version 5.5.42, there are issues with newer versions)
  2. Select Server only
  3. Create a password when asked
  4. Select that you want the database to have network access when prompted during installation.
Run the following command in powershell or execute all the steps below.
<syntaxhighlight lang="text" enclose="div">
  1. Go to control panel and open Windows Firewall
  2. Click on Advanced Settings
  3. Click on Inbound Rules, then New Rule
  4. For the Rule Type, choose Port and hit Next
  5. For Protocol and Ports, select TCP protocol and type in 3306 for the Specific local ports and hit Next
  6. For Action, leave it at default which is Allow the connection and hit Next
  7. For Profile, you can leave it as default (everything checked by default) and hit Next
  8. For Name, set it to MySQL or any name that you will know what it is and click Finished
Windows XP Built-in Firewall
  1. Open Control Panel and Set to 'Classic View'
  2. Double Click on Windows Firewall
  3. Click on tab that says Exceptions
  4. Click on Add Port
  5. Name it MySQL or any other name
  6. Set the port number to 3306
  7. Choose TCP and click OK
  1. Open the "MySQL Command Line Client" from the MySQL start menu
  2. Enter the following commands:
  3. Close out the command line tool
Note: If mrmc is unable to connect to the MySQL server, returning an error code [1130]:
If this occurs to you, try amending Step 2 above to read GRANT ALL ON *.* TO 'mrmc'@'xxx.xxx.xxx.%'; where xxx.xxx.xxx is the first three quadrants of your home network's IP address (192.168.1 for example) and % as the last quadrant to allow addresses on the same subnet to connect.
tab6 = Other NAS MySQL can also be installed on some network-attached storage (NAS) device devices. Here are some guides for various NAS devices that can have a MySQL server installed:
tab7 = FreeNAS and freeBSD
About FreeNAS
http://www.freenas.org/
How to
Make a jail
Prepare the jail
type the following commands
  • jls
  • jexec n csh
Install mysql
You are now inside your jail
  • pkg install mysql55-server
  • pkg install nano
    • (nano is a text editor you will need shortly)
  • nano /etc/rc.conf
  • mysql_enable="YES"
  • service mysql-server start
  • mysql_secure_installation
type in
  • mysql -u root -p
  • CREATE USER 'mrmc' IDENTIFIED BY 'mrmc';
  • GRANT ALL ON *.* TO 'mrmc';
  • flush privileges;
  • quit;
tab8 = Restricting MySQL access rights Optional: If you only use the MySQL server for mrmc and that server has non-critical data on it, then this probably not necessary. For a more secure MySQL installation use these 2 commands to grant permission only to databases mrmc uses. This is useful if you plan on using your MySQL server for more than just mrmc, or if you're worried about your internal network being exposed and wanting to lock things down more, etc.
  1. GRANT ALL ON `MyMusic%`.* TO 'mrmc'@'%' IDENTIFIED BY 'mrmc';
  2. GRANT ALL ON `MyVideos%`.* TO 'mrmc'@'%' IDENTIFIED BY 'mrmc';
