MySQL
Intro here
Compatibility
Ubuntu Linux
Ubuntu Linux:
$sudo apt-get install mysql-server(see also: https://help.ubuntu.com/10.04/serverguide/C/mysql.html )- Create a password when asked
- To configure MySQL to listen for connections from network hosts, edit /etc/mysql/my.cnf and change the bind-address directive to the server's IP address:
bind-address = 127.0.0.1 - to:
bind-address = 192.168.0.5
- Note: Replace 192.168.0.5 with the appropriate address.
- Note: To allow both local and remote access (i.e. from both the MySQL host to itself and also from other clients), either comment out the bind-address using a hash (#) to disable it, or use
bind-address = 0.0.0.0to open it completely.
- Restart your MySQL server.
$sudo restart mysql - Get into the MySQL command line utility:
$mysql -u root -p - Enter the following commands:
- Type in:
CREATE USER 'mrmc' IDENTIFIED BY 'mrmc';and press return - Type in:
GRANT ALL ON *.* TO 'mrmc';and press return - Type in:
flush privileges;and press return
- Type in:
- Close out the command line tool with
\q
Arch Linux
Arch Linux:
- Please note: Arch, along with many other distributions, has migrated to the faster and more open MariaDB. It is a drop in replacement to MySQL and, thus, mrmc will require no modifications to work with it.
- Install MariaDB:
$ sudo pacman -S mariadb - Start the service:
$ sudo systemctl start mysqld - To have it automatically launch at startup:
$ sudo systemctl enable mysqld - Create a password:
$ /usr/bin/mysql_secure_installationThis will also clean up the demo database. - Get into the MariaDB command line utility:
$ mysql -u root -p - Enter the following commands:
- Type in:
- Type in:
\q
RedHat based Linux
$sudo yum install mysql-server- Create a password when asked
- To configure MySQL to listen for connections only from network hosts, edit /etc/mysql/my.cnf and add the bind-address directive to the server's IP address:
bind-address = 192.168.0.5- Note: Replace 192.168.0.5 with the appropriate address.
- Note: Alternatively you can leave this file as is to allow local and remote access.
$sudo /sbin/service mysqld restart- Recommended - Set your MySQL root password with
/usr/bin/mysqladmin -u root password 'new-password'
$mysql -u root -p- Enter your MySQL root password as set above, or just press enter if you didn't set one to log in with a blank password
- Type in:
- Type in:
\q
Mac OS X
Mac OS X:
- Download a copy of MySQL server from http://dev.mysql.com/downloads/mysql/
- In Mac OS X, go to System Preferences -> MySQL, and click on “Start MySQL Server”. You’ll also want to tick to enable the “Automatically … on Startup” option.
- Now to set up the "mrmc" user in MySQL and give it access. Launch Terminal.app on your Mac and issue the following commands, one line at a time:
sudo /usr/local/mysql/bin/mysqlCREATE USER 'mrmc' IDENTIFIED BY 'mrmc';GRANT ALL ON *.* TO 'mrmc';exit
- Remain in Terminal.app. Now you'll be giving other computers on your network access to MySQL. Enter the next set of commands, one line at a time:
cd /usr/local/mysql/support-files/sudo cp my-huge.cnf /etc/my.cnf- The command line will ask for your Mac OS X user password. Enter it and press return. No text will show when you type your password in, this is normal.
cd /etcsudo nano my.cnf- This opens a file in a command line text editor
- Scroll down to the [mysqld] section and add or edit the following line so that it appears as:
- Save and exit from the command line text editor
- Reboot the Mac, or restart the MySQL service from the System Preferences pane you installed earlier
- Alternative guide for Mac OS X: http://forum.mrmc.tv/showthread.php?tid=151631
Windows
Installing MySQL on Windows
- or
- Download a copy of MySQL server from http://dev.mysql.com/downloads/mysql/ (Grab version 5.5.42, there are issues with newer versions)
- Select Server only
- Select that you want the database to have network access when prompted during installation.
- Run the following command in powershell or execute all the steps below.
- <syntaxhighlight lang="text" enclose="div">
- Go to control panel and open Windows Firewall
- Click on Advanced Settings
- Click on Inbound Rules, then New Rule
- For the Rule Type, choose Port and hit Next
- For Protocol and Ports, select TCP protocol and type in 3306 for the Specific local ports and hit Next
- For Action, leave it at default which is Allow the connection and hit Next
- For Profile, you can leave it as default (everything checked by default) and hit Next
- For Name, set it to MySQL or any name that you will know what it is and click Finished
Windows XP Built-in Firewall
- Open Control Panel and Set to 'Classic View'
- Double Click on Windows Firewall
- Click on tab that says Exceptions
- Click on Add Port
- Name it MySQL or any other name
- Set the port number to 3306
- Choose TCP and click OK
- Open the "MySQL Command Line Client" from the MySQL start menu
- Type in:
- Type in:
If this occurs to you, try amending Step 2 above to read GRANT ALL ON *.* TO 'mrmc'@'xxx.xxx.xxx.%'; where xxx.xxx.xxx is the first three quadrants of your home network's IP address (192.168.1 for example) and % as the last quadrant to allow addresses on the same subnet to connect.
Other NAS
- Devices running Arch Linux ARM (such as the PogoPlug, Dockstar, etc) can use the Arch Linux instructions on this page.
- Synology NAS as MySQL server for XBMC and http://youtu.be/3PmmDtK65ks
- http://www.robvanhamersveld.nl/2013/02/05/share-your-xbmc-12-0-library-on-a-synology-ds-or-other-nas/ Synology DS with MySQL guide based on Frodo
- http://forum.mrmc.tv/showthread.php?tid=172548 - unRAID
FreeNAS and freeBSD
About FreeNAS
How to
Make a jail
Prepare the jail
- ssh into FreeNAS
- If you have a windows PC use putty (http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html)
- (easiest) click the "shell" button in the left of the FreeNAS webui
type the following commands
jls
jexec n csh
Install mysql
You are now inside your jail
pkg install mysql55-server
pkg install nano- (nano is a text editor you will need shortly)
nano /etc/rc.conf
mysql_enable="YES"
service mysql-server start
type in
mysql -u root -p
CREATE USER 'mrmc' IDENTIFIED BY 'mrmc';GRANT ALL ON *.* TO 'mrmc';flush privileges;quit;
Restricting MySQL access rights
GRANT ALL ON `MyMusic%`.* TO 'mrmc'@'%' IDENTIFIED BY 'mrmc';GRANT ALL ON `MyVideos%`.* TO 'mrmc'@'%' IDENTIFIED BY 'mrmc';
<headertabs />
