Template:Code
Revision as of 23:31, 28 June 2016 by NedScott (talk | contribs) (44 revisions imported: formatting templates from kodi wiki)
<syntaxhighlight lang="text" enclose="none">​{{{1}}}​</syntaxhighlight>
[edit] Template documentation
Usage
Wraps a short span of text in <syntaxhighlight> tags (see mw:Extension:SyntaxHighlight GeSHi). This template should be used for short samples; longer content should use <pre>...</pre> or <syntaxhighlight>...</syntaxhighlight>.
If the content includes an equals sign (=), you must specify the parameter explicitly: {{code|1=date=30 Feb 2010}}.
The template uses the <syntaxhighlight> tag with the attribute enclose="none". This works like the combination of the <code> and <nowiki> tags, applied to the expanded wikitext. For example, {{code|some '''wiki''' text}} will not render the word "wiki" in bold, and will render the tripled-single-quotes:
<syntaxhighlight lang="text" enclose="none">​some wiki text​</syntaxhighlight>
However, {{code|a {{template}} call}} will still invoke the template:
<syntaxhighlight lang="text" enclose="none">​a {{[[Template:{{{1}}}|{{{1}}}]]}} call​</syntaxhighlight>
Use <nowiki>...</nowiki> around the template name to avoid this problem:
<syntaxhighlight lang="text" enclose="none">​a {{template}} call​</syntaxhighlight>
When used inline with regular text, {{code}} generally looks best and is easiest to read when it is explicitly spaced apart from the regular text:
<syntaxhighlight lang="text" enclose="none">​foo  {{code|bar baz}}  quux.​</syntaxhighlight>
is well spaced:
foo  <syntaxhighlight lang="text" enclose="none">​bar baz​</syntaxhighlight>  quux.
versus:
which is going to be visually confusing for many:
because "foo" and "<syntaxhighlight lang="text" enclose="none">​bar​</syntaxhighlight>" will seem more closely associated than "<syntaxhighlight lang="text" enclose="none">​bar​</syntaxhighlight>" and "<syntaxhighlight lang="text" enclose="none">​baz​</syntaxhighlight>"; the width of the space character in a monospaced font is almost always larger than in a proportional font.
Use parameter {{{2}}} (unnamed, as |2=, or more explicitly as |lang=) to specify a language for Extension:SyntaxHighlight GeSHi. This option defaults to plain-text, i.e. no highlighting. There is no highlighting option for wikitext as a markup language, though <syntaxhighlight lang="text" enclose="none">​html4strict​</syntaxhighlight> and <syntaxhighlight lang="text" enclose="none">​html5​</syntaxhighlight> are valid values, as are <syntaxhighlight lang="text" enclose="none">​php​</syntaxhighlight>, <syntaxhighlight lang="text" enclose="none">​perl​</syntaxhighlight>, <syntaxhighlight lang="text" enclose="none">​css​</syntaxhighlight>, <syntaxhighlight lang="text" enclose="none">​javascript​</syntaxhighlight>, <syntaxhighlight lang="text" enclose="none">​mysql​</syntaxhighlight> and many others. Attempting to use an invalid one causes a list of valid ones to be displayed in place of the template output, when the page is previewed or saved.
This template does not need to be substituted.
Finally, embedded templates do not function inside {{code}}; for longer, free-form blocks of code, which can contain templates, use <code>...</code> as a wrapper instead of this template.
Examples
input output
Lorem {{code|ipsum '''dolor'''}} sit amet
Lorem <syntaxhighlight lang="text" enclose="none">​ipsum dolor​</syntaxhighlight> sit amet
The declaration {{code |lang=cpp |int foo(const std::string& bar, const std::vector<long double*>& baz);}} is the prototype for a function defined later.
The declaration <syntaxhighlight lang="cpp" enclose="none">​int foo(const std::string& bar, const std::vector<long double*>& baz);​</syntaxhighlight> is the prototype for a function defined later.
If the code contains an [[equals sign]], such as {{code |lang=javascript |code=var img = document.getElementsByTagName("img");}}, you must identify the first parameter explicitly as {{{1}}} or {{{code}}}; see also [[:bugzilla:5138]].
If the code contains an equals sign, such as <syntaxhighlight lang="javascript" enclose="none">​var img = document.getElementsByTagName("img");​</syntaxhighlight>, you must identify the first parameter explicitly as {{{1}}} or {{{code}}}.
