Template:Tnull/doc
< Template:Tnull
Revision as of 22:15, 3 July 2016 by NedScott (talk | contribs) (24 revisions imported)
Usage
Tnull is used to nullify templates in the monospaced font. It is similar to {{tlx}} in the way that it has support for many parameters.
Example
Typing {{tnull|foo|bar|baz|boo}} in the "edit-form" would yield {{foo|bar|baz|boo}} in the "read-mode".
Note on the "=" character
If there is a "=" character in any parameter, you must replace it with &#61; as in:
{{tnull|click|image&#61;image name|width&#61;width|height&#61;height|link&#61;page name}}
Or you can use parameter-number=value as in:
{{tnull|click|2=image=image name|3=width=width|4=height=height|5=link=page name}}
Either method would yield the following output:
{{click|image=image name|width=width|height=height|link=page name}}
