Template:Tlx/doc
< Template:Tlx
Revision as of 19:03, 9 May 2008 by 87.166.231.28 (talk) (german interwiki)
Template:Template doc page viewed directly
Template:Interwikitmp-grp
{{tlx|template|first parameter|second|third|fourth|fifth|sixth|seventh|eight|ninth}}{{template|first parameter|second|third|fourth|fifth|sixth|seventh|eight|ninth}}
Purpose and naming: Mnemonically 'Template list expanded'... after {{tl}} Template list'
  • This template takes another template-name and some associated pipe-tricked (numbered) parameters (or 'pass parameters'), and displays them as an 'example demonstration' of how the template-name template could be coded, literally. Its primary use is in instruction and documentation.
  • Specifics: Up to five pass parameters (numbered or nowiki-keywords) for the specified template are displayed as 'placeholders', and over 5 parameters can be displayed using a coded vertical-bar (as in "&#124;..."). A keyword parameter can be used, when tagged as a nowiki-keyword: "<nowiki>siz=10<\nowiki>" with each keyword parameter surrounded by "<nowiki>" tags; see Examples at bottom. For more details, see the this talk page.
  • Exceptions: If the intended template lists numerous/keyword parameters, then perhaps this template should really not be used, and just hardcode the usage in double-braces, putting only nowiki-braces "{{" to start, such as: "<nowiki>{{<\nowiki>Anytemplate |arg1=23 |siz=250px}}".
  • If given no additional parameters except  'template name' ({{{1}}}),  it presents the same as the similar {{Tl}} macro template -- a blue link nested in curly-braces-- the same as a user would apply the template without parameters, but with a noticably clearer font and spacing on most modern browsers.
  • {{Tl|Tl}} display compared to {{Tlx|Tl}}: (Tl: {{Tlx}} versus Tlx: {{Tl}})
  • Comparatively, {{Tl}} will not take or display additional parameters, and for minor technical reasons, may preferred for mere listing and referencing in long pages involving a lot of template expansions1.
  • Additionally, Tlx will take a 'named' parameter 'SISTER' to link interwiki to other sister projects such as one of these examples: '|SISTER=W:', 'Tlx|SISTER=M:', 'Tlx|SISTER=Q:', 'Tlx|SISTER=S:', allowing documentation or discourse about a template across interwiki boundaries. Small 'front end' Shell or convience templates {{Tlxw}} and {{Tlxm}} are typing-aid templates available at Meta for automatic substitution in discussions about templates on Wikipedia or Meta.
This usage also applies to interwiki capable template variations
  1. {{Tlxc}} -- which links to templates on Wikimedia Commons (The Commons).
  2. {{Tlxm}} -- which links to templates on Meta
  3. {{Tlxw}} -- which links to templates on Wikipedia
Documentation
{{Tlx/doc}} is a generalization of Template:Tlxw, Template:Tlxw, etcetera with arguably better readable output. This depends on the browser, but too narrow uses of "{", "|", "}" in conjunction with links can be hard to read.
Examples
Note
On the source sister projects, en.wikipedia and Meta, X0, X1, X2,..., X9 are sandbox templates for experimentation on involved templates that need be in template space. An auto-cleansing software facility exists that might be used to duplicate the facility on other Sister projects.
Code Result Remark
{{Tlx|x0}} {{x0}}
{{Tlx|Abc}} {{Abc}}
{{Tlx|ABC}} {{ABC}}
{{Tlx|AbC}} {{AbC}}
{{Tlx|x1|one}} {{x1|one}}
{{Tlx|x2|one|two}} {{x2|one|two}}
{{Tlx|x3|1|2|3}} {{x3|1|2|3}}
{{Tlx|x4|1|2|3|4}} {{x4|1|2|3|4}} up to 5 parameters, then ...
{{Tlx|x4|1|2|3&#124;4}} {{x4|1|2|3|4}} &#124; for more
{{Tlx|x1|x=u}} {{x1}} = won't work
{{Tlx|x1|x&#61;u}} {{x1|x=u}} &#61; is okay
{{Tlx|x1|x{{=}}u}} {{x1|x=u}} {{=}} is okay
{{Tlx|x1|<nowiki>x=u</nowiki>}} {{x1|x=u}} sticky nowiki is okay
{{Tlx|x2| |two}} {{x2|two}} empty won't work
{{Tlx|x2|&#32;|two}} {{x2| |two}} &#32; is okay
{{Tlx|x2|&nbsp;|two}} {{x2| |two}} &nbsp; is okay
{{Tlx|x2| &#124; two}} {{x2| | two}} &#124; is okay
{{Tlx|x2| {{!}} two}} {{x2| | two}} {{!}} is dubious
{{Tlx|x2|2=|3=two}} {{x2|two}} empty really doesn't work
{{Tlx|x2|2=one|two}} {{x2|two}} two clobbers 2=one
{{Tlx|x2|3=two|2=one}} {{x2|one|two}} right to left okay
