Template:Smaller
Revision as of 22:01, 3 July 2016 by NedScott (talk | contribs) (Created page with "<small style="font-size:50%;">{{{1}}}</small><noinclude>{{doc}}</noinclude>")
{{{1}}}
[edit] Template documentation
Syntax
Examples
Shortcuts
