Template:TOC right/doc
< Template:TOC right
{{TOC right}} forces the auto-generated Table of Contents for a page to appear in a table that is floated to the right side of the page, in order to improve page layout.
Usage
Insert {{TOC right}} at the point in the page where you want the top of the Table of Contents box to appear. Use with {{-}} or {{clear}} to prevent collision with text; use the clear parameter (see below) to prevent collision with images.
Parameters (optional)
clear
Sets the CSS clear property, which forces this float underneath the side specified with this attribute. So, clear=right (which is the default) will place the element after all the right floating elements before it. Options are left, right, both, or none.
width
Set the CSS width.
limit
See also
