Template:See also/doc
< Template:See also
Usage
{{See also}} is used to create hatnotes to point to a small number of other, related, titles at the top of pages or sections. It is not for use in the "See also" section at the bottom of a page.
{{See also|Page 1|...|Page 15}}
  • One to fifteen pages can be listed.
  • The word "and" is always placed between the final two entries.
  • If more than 15 entries are supplied, a message will be displayed pointing out the problem.
  • You can use parameters label 1 to label 15 to specify alternative labels for the links.
adding newline characters will break article links
Example
Code Result
{{See also|Page}}
{{See also|Page|label 1=Alternative title for Page}}
{{See also|Page|Page 2}}
{{See also|Page|Page 2|Page 3}}
{{See also|Page|Page 2|label 2=Alternative title for Page 2}}
And so on up to 15 parameters.
See also: Link to section
It is possible to direct this template to link a particular section within another page.
{{See also|Add-ons#Updating|l1=Updating}} gives
See also
