Template:Infobox/doc
< Template:Infobox
This template is intended as a meta-template: a template used for constructing other templates. It is not meant for use directly in an article, but can be used on a one-off basis if required. See w:Help:Infobox for an introduction to infoboxes and information on how to design them.
Usage
Each row on the table can contain either a header, or a label/data pair, or just a data cell. These are mutually exclusive states so if you define a row with both a header and a label/data pair, the label/data pair is ignored.
To insert an image somewhere other than at the top of the infobox, or to insert freeform data, use a row with only a data field.
Number ranges
Row numbers may be from 1 to 80. To allow flexibility when the layout of an infobox is changed, it may be helpful when developing an infobox to use non-contiguous numbers for header and label/data rows. Parameters for new rows can then be inserted in future without having to renumber existing parameters. For example:
|header3  = Section 1
|label5   = Label A
|data5    = Data B
|label7   = Label C
|data7    = Data C
|header10 = Section 2
|label12  = Label D
|data12   = Data D
Parameters
Title
Text in caption over infobox
Subheader of the infobox
(the rest of the infobox goes here)
Text in uppermost cell of infobox
Second subheader of the infobox
There are two different ways to put a title on an infobox. One contains the title inside the infobox's border, the other puts it on top as a caption. You can use both of them together if you like, or just one or the other, or even neither (though this is not recommended).
title
Text to put in the caption over top of the table.
above
Text to put within the uppermost cell of the table.
Optional content
subheader, subheader2
additional title fields which fit between {{{title}}} and {{{above}}}.
image, image2
images to display at the top of the template. Use full image syntax, for example [[File:example.png|200px|alt=Example alt text]]. Image is centered by default. See WP:ALT for more on alt text.
caption, caption2
Text to put underneath the images.
header(n)
Text to use as a header in row n.
label(n)
Text to use as a label in row n.
data(n)
Text to display as data in row n.
below
Text to put in the bottom cell. The bottom cell is intended for footnotes, see-also, and other such information.
child
See the embedding section for details.
Note: for any given value for (n), not all combinations of parameters are permitted. The presence of a |header(n)= will cause the corresponding |data(n)=|label(n)= (and |rowclass(n)=, see below) to be ignored; the absence of a |data(n)= will cause the corresponding |label(n)= to be ignored. Valid combinations for any single row are:
  • |header(n)= |class(n)=
  • |data(n)= |rowclass(n)= |class(n)=
  • |label(n)= |data(n)= |rowclass(n)= |class(n)=
See the rendering of header4, label4, and data4 in the examples section below.
Optional CSS styling
bodystyle
Applies to the infobox table as a whole
titlestyle
Applies only to the title caption. Adding a background color is usually inadvisable since the text is rendered "outside" the infobox.
abovestyle
Applies only to the "above" cell at the top. The default style has font-size:large; since this cell is usually used for a title, if you want to use the above cell for regular-sized text include "font-size:medium;" in the abovestyle.
imagestyle
Applies to the cell the image is in. This includes the text of the image caption, but you should set text properties with captionstyle instead of imagestyle in case the caption is moved out of this cell in the future.
captionstyle
Applies to the text of the image caption.
headerstyle
Applies to all header cells
labelstyle
Applies to all label cells
datastyle
Applies to all data cells
belowstyle
Applies only to the below cell
HTML classes
bodyclass
This parameter is inserted into the "class" attribute for the infobox as a whole.
titleclass
This parameter is inserted into the "class" attribute for the infobox's title caption.
aboveclass
This parameter is inserted into the "class" attribute for the infobox's "above" cell.
aboverowclass
This parameter is inserted into the "class" attribute for the complete table row the "above" cell is on.
subheaderclass
This parameter is inserted into the "class" attribute for the infobox's subheader.
subheaderrowclass
This parameter is inserted into the "class" attribute for the complete table row the subheader is on.
imagerowclass1, imagerowclass2
These parameters are inserted into the "class" attribute for the complete table row the respective images are on.
rowclass(n)
This parameter is inserted into the "class" attribute for the specified row including the label or other explanatory text.
class(n)
This parameter is inserted into the "class" attribute for the data cell of the specified row. If there's no data cell it has no effect.
belowclass
This parameter is inserted into the "class" attribute for the infobox's below cell.
Italic titles
Titles of articles with infoboxes may be made italic, in line with WP:ITALICTITLE, by passing the italic title parameter.
  • Turn on italic titles by passing |italic title={{{italic title|}}} from the infobox.
  • Turn off by default but allow some instances to be made italic by passing |italic title={{{italic title|no}}}
  • Do not make any titles italic by not passing the parameter at all.
Making fields optional
A row with a label but no data is not displayed. This allows for the easy creation of optional infobox content rows. To make a row optional use a parameter that defaults to an empty string, like so:
|label5 = Population
|data5  = {{{population|}}}
This way if an article doesn't define the population parameter in its infobox the row won't be displayed.
For more complex fields with pre-formated contents that would still be present even if the parameter wasn't set, you can wrap it all in an "#if" statement to make the whole thing vanish when the parameter is not used. For instance, the "#if" statement in the following example reads "#if:the parameter mass has been supplied |then display it, followed by 'kg'":
|label6 = Mass
|data6  = {{#if:{{{mass|}}}|{{{mass}}} kg}}
For more on #if, see here.
You can also make headers optional in a similar way. If you want a header to appear only if one or more of the data fields that fall under it are filled, one could use the following pattern as an example of how to do it:
{{Infobox
|name    = {{subst:PAGENAME}}
|title   = Example of an optional header
|header1 = {{#if:{{{item_one|}}}{{{item_two|}}}{{{item_three|}}}|Optional header}}
|label2  = Item one
|data2   = {{{item_one|}}}
|label3  = Item two
|data3   = {{{item_two|}}}
|label4  = Item three
|data4   = {{{item_three|}}}
header1 will be shown if any of item_one, item_two, or item_three is defined. If none of the three parameters are defined the header won't be shown.
The trick to this is that the "if" returns false only if there is nothing whatsoever in the conditional section, so only if all three of item_one, item_two and item_three are undefined will the if statement fail.
Examples
Test Infobox
Example alt text
Header defined alone
Data defined alone
All three defined (header, label, data, all with same number)
Label and data defined (label) Label and data defined (data)
Below text
{{Infobox
|bodystyle    =
|title        = Test Infobox
|titlestyle   =
|image        = [[File:example.png|200px|alt=Example alt text]]
|imagestyle   =
|captionstyle =
|headerstyle  = background:#ccf;
|labelstyle   = background:#ddf;
|datastyle    =
|header1 = Header defined alone
|label1  =
|data1   =
|header2 =
|label2  = Label defined alone does not display (needs data, or is suppressed)
|data2   =
|header3 =
|label3  =
|data3   = Data defined alone
|header4 = All three defined (header, label, data, all with same number)
|label4  = does not display (same number as a header)
|data4   = does not display (same number as a header)
|header5 =
|label5  = Label and data defined (label)
|data5   = Label and data defined (data)
|belowstyle = background:#ddf;
|below = Below text
Notice how when a label is defined without an accompanying data cell the row doesn't appear in the displayed infobox, and when a header is defined on the same row as a data cell all of them are displayed.
For this example, bodystyle = width:20em; and labelstyle = width:33%;
Test Infobox
Label 1 Data 1
Label 2 Data 2
Label 3 Data 3
Header 4
Label 5 Data 5: Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Below text
{{Infobox
|titlestyle  =
|headerstyle =
|datastyle   =
|header1 =
|label1  = Label 1
|data1   = Data 1
|header2 =
|label2  = Label 2
|data2   = Data 2
|header3 =
|label3  = Label 3
|data3   = Data 3
|header4 = Header 4
|label4  =
|data4   =
|header5 =
|label5  = Label 5
|data5   = Data 5: Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
|belowstyle =
|below = Below text
Embedding
One infobox template can be embedded into another using the |child= parameter. This feature can be used to create a modular infobox, or to create more well defined logical sections.
Top level title
First subsection
Label 1.1 Data 1.1
Second subsection
Label 2.1 Data 2.1
Below text
{{Infobox
| title = Top level title
| data1 = {{Infobox
  | child = yes
  | title = First subsection
  | label1= Label 1.1
  | data1 = Data 1.1
| data2 = {{Infobox
  | child = yes
  | title = Second subsection
  | label1= Label 2.1
  | data1 = Data 2.1
|belowstyle =
|below = Below text
Full blank syntax
(Note: the template currently handles up to 80 rows; only 20 are included here since infoboxes larger than that will be relatively rare. Just extend the numbering as needed. The microformat "class" parameters are also omitted as they are not commonly used.)
{{Infobox
|bodystyle    =
|title        =
|titlestyle   =
|above        =
|abovestyle   =
|imagestyle   =
|captionstyle =
|image        =
|caption      =
|image2       =
|caption2     =
|headerstyle  =
|labelstyle   =
|datastyle    =
|header1  =
|label1   =
|data1    =
|header2  =
|label2   =
|data2    =
|header3  =
|label3   =
|data3    =
|header4  =
|label4   =
|data4    =
|header5  =
|label5   =
|data5    =
|header6  =
|label6   =
|data6    =
|header7  =
|label7   =
|data7    =
|header8  =
|label8   =
|data8    =
|header9  =
|label9   =
|data9    =
|header10 =
|label10  =
|data10   =
|header11 =
|label11  =
|data11   =
|header12 =
|label12  =
|data12   =
|header13 =
|label13  =
|data13   =
|header14 =
|label14  =
|data14   =
|header15 =
|label15  =
|data15   =
|header16 =
|label16  =
|data16   =
|header17 =
|label17  =
|data17   =
|header18 =
|label18  =
|data18   =
|header19 =
|label19  =
|data19   =
|header20 =
|label20  =
|data20   =
|belowstyle =
|below =
