Template:Key press
Revision as of 20:28, 30 September 2011 by 72.211.252.69 (talk) (now 10)
{{{1}}}
[edit] Template documentation
Example:
{{key press|A}} produces A
Keystroke combinations
This template currently handles up to 5 key name parameters; more than enough to accomodate for any possible combined key stroke. If it gets too many key name parameters it reports the page into Category:Keypress template parameter needs fixing. This means we can easily find those pages and fix them, or we can discover if we need to make this template take more parameters.
Wikilinks
{{key press|[[w:Alt key|Alt]]}} produces Alt
Wiki characters
Alternately, {{key press|<nowiki>|</nowiki>}} is also an option.
Key symbols
{{key press|Up}} produces
{{key press|Down}} produces
{{key press|Left}} produces
{{key press|Right}} produces
Video games
Directional input
Technical details
See also
  • {{Button}} – produces a similar visual effect, but without the semantic markup, e.g. sample text
