Audio Setup
Passthrough on tvOS 11.3 is broken by Apple, none of the applications are able to use it.
AppleTV Settings
Apple TV -> Settings -> Video and Audio
Surround Sound: Best Quality Available
Forcing Surround Sound to "Dolby Digital 5.1" might solve issues with receiver that do not support multi channel PCM or if the setup uses ARC
Reduce Loud Sounds: Off
Audio Mode: Auto
MrMC Settings
Ariana=Settings -> System -> Audio output
Number of channels: default 2.0 (stereo output), set according to your receiver/TV setup
